Getting ready to mount a thru-hull depth transducer. Where does one buy 2.4 ounces of Propylene Glycol?
Propylene glycol?-gctid384525
im using it for my tobacco and i bought at
freedomsmokeusa
If you are using medium fluid you have the in-hull transducer. The through hull implies you drill a hole through the hull to mount a transducer and it does not require any fluid. If you have in-hull transducer you should have a mounting flange that is glued to the inside of the hull and filled with fluid before mounting a transducer on top of the flange.
that is no-tox antifreeze
Long Island Sound RegionComment
88fourwinns wrote:
that is no-tox antifreezeJust about ANY liquid will work there, the anti-freeze just doesn't... freeze.
ishiboo wrote:
+1. Just regular RV/Marine anti-freezeJust about ANY liquid will work there, the anti-freeze just doesn't... freeze.
