Hi. I'm sure someone knows the answer to the whereabouts of the freshwater sender units in a 2000, 4788. There are two water tanks in the bow area labelled as forward and aft. I found the sender for the forward tank (under a little hatch in a storage locker under the master bed), but the aft tank???
I can see the tank (under the master suite floor) by removing the breezeway step into the master and unscrewing the bulkhead cover. The aft tank outlet pipe is there, but anyone know whether a "chainsaw"
is required to gain access to the tank/sender unit or an easy way to get to it??
Many thanks. Cheers
Many thanks. Cheers
