Hi All,
I will be installing a Seaward F600 (6 gal) hot water tank and have a few questions (Please see attached photo and installation manual):
In the attached photo the water lines on the left that is connected with tees is what the previous owner did after removing the original water tank.
Questions:
1. The fittings on the tank are clamp style while the boat uses NPT pressure fittings. I doubt I can use a clamp on that style hose, can I get NPT fittings to go on the hot water tank or do I get clamp style fittings to come off the waterlines tees.
2. Where can I buy these type of plumbing connectors and hoses in Canada, do they carry them at the big box home reno stores?
3. Lastly the installation manual is pretty vague and in the diagram to connect it through the engine using a heat exchanger, I can't tell where the coolant lines coming off engine? Is it off the thermostat?
Thanks in advance for any assistance, BOC has been a great resource for me and I try to contribute when I can.
Cheers
Attached files [img]/media/kunena/attachments/vb/687513=27920-Hot Water Tank.jpg[/img] [img]/media/kunena/attachments/vb/687513=27922-Seaward Water Heater_Page_5.jpg[/img] [img]/media/kunena/attachments/vb/687513=27923-Seaward Water Heater_Page_6.jpg[/img] [img]/media/kunena/attachments/vb/687513=27924-Seaward Water Heater_Page_7.jpg[/img]
Questions:
Cheers
