2050ss 5.7L bog issue?-gctid383915
  • 2050ss 5.7L bog issue?-gctid383915
    Morning folks!
    Just put the boat in the water this weekend at the cottage.
    The mechanic recently did a tune-up last week (plugs, wires, ignition coil, distributor cap and rotor).
    Upon releasing the boat from the trailer, i puttered around a little, make sure everything ran fine and got to operating temp before opening it up.
    Later that day, we loaded people in the boat for a evening cruise on the lake, i was at about 3/4 throttle when all of a sudden i started to lose power and slow down. I did i sharp left turn to head back to the cottage so none of us were stranded. During this turn you could hear the engine gaining momentun again. I dropped the trottle to wot and the boat hesitated and did nothing.
    I opened the engine bay to look into it. nothing seemed out of place..plug wires didnt slip off, cap didnt move causing any type of timing issue (that i know of).
    I decided to try it again...i started the boat and noticed a "blue cloud trail of fumes/smoke"..thinking it was just gas in the carbs burning off.
    i reverse, neutral, than drop the throttle, the boat go to MAYBE 20mph before hesitating again.
    i also notice at idle it had a "shutter" feel.
    Any ideas / thoughts / comments ?
    Thanks in advance for your replies.
    Fox.
    BOAT: 1997 Baylienr 2050 SS
    Engine: 5.7L / 350 / V8
    check your water seperator .... water in gas?
      Apparently the mechanic had told me we have a faulty ignition switch....hopefully thats the fix?
        changed ignition - still same issues.
        One thing i noticed, is when i accelerate and the boat actually slows down, is that my battery volt meter gauge goes all whacky - very low voltage is where the needle points too -- is this possibly an alternator issue?
