Hi,
my port side engine is overheating when it gos above 3000 rmp, I have changed the manilfolds/risers, termostat, water pump impeler and housing, also I checked the water flow coming from the outdrive and the water flow is fine I am getting a lot of water coming in, but it still overheating, could anyone give me any idea what else could I check on it to repair the problem.
Welberson
2000 Bayliner ciera 3055
Welberson
