So after a few outtings this season, I've noticed that the power plant package of my boat is not doing what it's supposed to.
Standard merc cruiser 3.0L w/o alpha 1 gen 2 here. Last season I was able to do about 30mph @4000rpm and about 40mph WOT @ 4800 RPM, speed is measured with GPS so it's pretty accurate.
This season, I'm doing about 25mph @ 4000rpm and WOT I cannot get above 33mph @ 4800RPM.
I've ruled out the prop/hub slipping since I switched to an identical back up prop / hub and it's still doing the same thing.
I've noticed no obvious leaks or anything wrong anywhere. I did the standard winterizing last year, changed the impeller at the beginning of this season and everything went back fine and dandy.
Fuel filter was changed last season.
The load is the same in terms of weight, 2 adults, 20 gallons of fuel.
So I'm at the end of the line here in terms of my ability to diagnose issues.
Help please!
Help please!
