am trying to find early model tacho for my motor. it is a faria brand 5inch, black face with white numbering on a square bezel. on the bottom of the face has the words U.S MARINE in red lettering. can anyone please help..
tachometer for 210hp hino diesel motor-gctid382479
Hello - You can send the tachometer to Faria for repair. You can register your order online with them to keep track of the work. I sent mine in because it was stuck at 500 RPM. I came back all shiny but is still stuck at 500 RPM. I would expect they fix the problem most of the time.
