Boats been running like a champ with the new engine. Water is in the 280 drive now. I ordered a tester. Is it best to pressure check from the top (Dip Stick) or bottom ? both times after replacing oil and running it. When I took the dip stick out it made a "POP" sound? Reason I ask about the bottom when I took the lower unit screw out there was no "O" ring or gasket around the screw. Just wondering if its sucking in water there ?
Roger
Roger
