I just finished replacing my transom core and want to gelcoat the new fiberglass as well as the surrounding area. The problem is the surrounding has been flowcoated. I've read that if I sand the flowcoat, the wax styrene can get into the pores of the new fiberglass and make the gel coat bond poorly. How can I prep the flow coat without effecting the new fiberglass. Should I use plastic and tape to cover the new fiberglass while I sand the remaining area? Also, how much of the flowcoat needs to be removed. It seems as though the wax styrene was designed to float to the top so the flowcoat can harden. Does this mean just the surface needs to be sanded?
Greg
Greg
