Hi,
A friend of mine at the marina asked me if it's possible to relocate a sea water pump? His engine is a Volvo 8.1 on a 2855, I think the year is around 2000 something. Problem is that in order to change the impeller, the shop has to pull the engine each time because the pump is too close to the main fuel tank! I think there must be a way change the setup to either electric or something else. Your thoughts please.
Gary.
Gary.
