Is this flapper ok?-gctid344808
    I think this is called a Flapper on my VP 270 outdrive. Is it time to replace it or is it still ok?
    Thank you.
    Attached files [img]/media/kunena/attachments/vb/647437=23860-Flapper.jpg[/img]
    Bruce i would take it off and try to bend it back
    mabe upside down with something on it for a week or two
    you cant buy the flapper anymore
    you will have to buy the housing
      That one looks to be home made, as stated you cannot buy the rubber flap separately.
      If you can push it closed with a finger, then the water surging against it will also. If not then you may want to replace it.
      Here you go, make offer:
      " WET EVER "
      mmsi 338108404
      mmsi 338124956
        + 1
