2550 ciera power trim motor runs but tabs dont move-gctid666801
    89 My trim tabs make noise when i attemp to raise or lower them. It is a normal noise as you would expect when raising or lowering hydraulics but it does nothing to the tabs. The fluid level looks a little low but the boat is parked at an angle so its may be full if i flatten it out.
    Besides fluid what else should I be checking?
    Definitely check the fluid level. Automatic transmission fluid used.
