ciera 2550 command bridge dual steering issues-gctid666797
    Just picked up an 89 and the top steering works and the bottom does not. The steering cable/bar for the bottom is not hooked up. There does not appear to be a shaft for it to go into. From just glancing at it i would guess that someone put a normal steering components in when something broke on the one for command bridges?
    Is this making any sense?
    For now i am unhooking the upper steering cable and hooking up the lower, but i feel like there should be a shaft for both to operate at the same time.
