PLEASE HELP SUPPORT OUR SITE
I have a 91 2655 Ciera and for some reason the GFI's trip, killing power to everything when I have the batteries off position and try switching the panel to shore power. However, if the have the batteries selector set to 1, 2 or all everything works?
First of all, the GFI's are doing there job, and thats a good thing. A little hard to tell whats going on from your description, could be some thing as simple as a worn insulation on a conductor or maybe a recent change in wiring, add something or deleted something? Did you have this problem last fall or is it new this spring? Just looking for more info.
Thanks in advance
Are you connecting to a marina shore power or just a 15 amp service.
If you are getting any kind of reverse polarity the GFI will trip.
If the GFI is what you are feeding from in all likely hood your boat will not accept that power.
The test circuit that gives you the red or green light on your AC panel will trip a shore GFI every time.
I had to install a switch on my boat to cut out that circuit as I had to use shore power from a GFI from time to time.
You are still protected as the GFI is now deciding if you have reverse current.
The wiring behind my shore power receptacle was bad on my older boat. It looked like the insulation burned off. Most of the heat was due to poor wiring connections in the back of the plug. (plus water damage). Also, The PO may have run too much power through this plug. This caused the back of the receptacle and wiring to burn. I replaced the receptacle and wiring with a heavier gauge. Where the wires connected to the receptacle, I used 'RID OX' grease to improve the connection.
If you walk the harbors, you'll see burned up shore power plugs and receptacles from time to time.
