This one is driving me crazy. Let me start out by stating that the lower unit is a 1988 Cobra and the innards (gears, bearings,ect) have been inspected and everything looks great. The shifter and throttle cables are about 4 years old with maybe a seasonÔÇÖs total usage on them and operate smoothly when disconnected. The interrupt switch appears to be working. Engine idle is right at 650 RPMs and is running smooth. And all adjustments of the cables at the carb are correct according to the Sealoc manual that I have.
Now on to the problem. When running on the trailer, and shifting from forward to reverse and back through neutral to forward it shifts like it should, no real effort is required and the shifts are smooth. BUT itÔÇÖs another story altogether when the boat is in the water; especially if the boat is moving at all. It is very difficult to get the boat out of gear, but fairly east to get into gear. When docking (I have to dock stern in) sometimes the shift lever has to be moved all the way to the forward position to get the drive out of reverse; during this process quite a bit of force is required. Needless to say about half the time it goes into forward requiring a quick shift back into reverse or neutral. Also when creeping toward a dock it can be very difficult to shift out of forward into neutral to keep the speed down (boating rule #3: never approach a dock faster than you are willing to hit it). At my dock, with the speed of the current when the tide is running this can be a very aggravating issue, plus itÔÇÖs playing heck on my rub-rails from bouncing off the pilings.
I have checked and rechecked everything that I can think of at least three times and canÔÇÖt find anything out of adjustment or anything that looks worn. As much as I hate to, I might have to turn this one over to a marina that has a few techs who know their way around the OMC stern drive.
Is there anything that I may have overlooked?
