Johnson OB. 2004 will not raise.-gctid666130
    Good morning, good buddy at the marina is having a problem his lifting mechanism on his Johnson OB is not working, Battery is charged and engine runs, what's next?
    Help where have all the smarter then myself mechanic's gone
      Where is tilt/trim switch located? This happened on my Suzuki OB where the switch was located on the remote throttle. I tried replacing tilt/trim selenoid on the engine block but what I ultimately found is that years of using the remote had "pinched" the signal wire within the remote and essentially cut it so signal was not being sent. Took apart remote, patched/soldered wire and the OB raised up! :-) Check wiring....is moral of the story.
      2014 Flight Package 16' Element
      Upgrades: 90HP Merc, NFB Helm, Smart Tabs, 4 Blade 15P Prop, MercMonitor Gauge, Bimini Top, Custom Steering Wheel, Stainless Cup Holders, Radio w/4 speaker and Subwoofer + Amp
      Lacey, WA
        There is one switch at the helm and one on the engine, none are working.
          Check the trim selenoid then...it essentially acts as a relay...may have gone bad??? Does it tilt down? If it does neither then I'm at a loss....
          Lacey, WA
            Your friend is having a problem getting his Johnson up? :whistle:
            Esteban
            Vancouver, BC
              Check the fuse first.
                +1 with Chief Alan on the fuse. If fuse is OK, then trace wiring from fuse through to tilt hydraulic pump, checking with multimeter you have 12V when the switch is engaged.
                  Thanks all for the responses, fuse is good, I am thinking solenoid will check this weekend, having toooo many projects going, the marina is 80 mil from Great Falls.
