The boat comes home today from commissioning, yea! BUT, now starts the annual wash/clean/wax, ugh, my aching arms. My neighbor was out in his driveway this weekend and was using Soft Scrub to clean the gunk off his boat. It seemed to work pretty well, black streaks disappeared, and after he rinsed it well, the gelcoat looked ready for wax. Does anyone know if Soft Scrub is ok to use for cleaning? It's pretty cheap and looked relatively easy to use, spray on, scrub a bit w/ a clean cloth, hose it off. Just wondering if it's too harsh or something.
Soft Scrub - does it hurt the gelcoat?-gctid378933
Most shower enclosures in homes are made of fiberglass, just to compare how "home cleaners" may be different from boat cleaners. On the other hand, nobody expects them to be brightly polished and waxed. My concern would be that it may make the gelcoat dull or have swirl-marks. I don't know if it would, but that would be my thought.
I don't think trying it in a locker would do much. I think you need to try it in a small area you can get clear sunlight on and see if it looks dull or swirled.
I've used soft scrub (with bleach) for years and see a lot of other people using it on their boats too. Under normal circumstances I used it on the floors/walkways and areas with textured anti-slip surfaces. It's fantastic for cleaning those areas and turns even the ugliest spot nice and clean again. But I don't normally use it on areas where I've waxed, as I'm sure it removes the wax (e.g. a good cleaner likely takes off wax too). But I do use it for stubborn stains no matter where they are. I try to keep the scrubbing "focused" and use a scrub brush on the dirty areas, working in small areas at a time (a few square feet), and hose off immediately afterwards. With hosing off, it seems to dilute enough that it doesn't harm the waxed areas.
Been using soft scrub for a few years now to clean every thing up before pressure washing the cleaner wax. Seems to cut the cleaning time by quite abit.
