I have the thremostat houseing out- can i remove the old thremostat from the houseing or do i need a new houseing with a thremostat in it-
Replace thremostat 1987 omc 5.4l v8 2550-gctid378626
The thermostat is held in the housing with a rubber ring that fits into a groove in the housing, you have to pry out the ring with a small screwdriver to get the stat out. The ring will probably be disguised with rust so scrape that off and you should see the ring.
Long Island Sound Region
Might be important to know, based on what you are trying to do.
Matt Train
BOC Site Team
Chicagoland, IL
