Lately my bayliner has been a [email protected]$Ôé¼~┬Ñ*+#. If I had more strange icons to represent curse words I would use them.
New engine, sweet new remote kicker set up, bunch of other maintenance and fishing goodies given to her this winter and spring. Is that enough for her? Nooooooooo. A fuel in the bilge problem was noticed at first fill up several weeks ago. Looked like the fill hose was seeping, had it replaced (it was pretty cracked and worn). No more gas in bilge. Great.
Yesterday went down to splash and begin break-in of the new base engine. Gas in bilge, lots of it.
Got the boat tilted to run off into a catch bucket, clearly there is a drip coming from under the tank.
$&@?!#%^*+=~Ôé¼┬ú┬Ñ!
Looking for pointers on cost, tank supliers, and any experiences pulling out the old aluminum 60 gallon behind the bulkhead separating wall. Pull motor, check. Cut out bulkhead, huh? Will old tank slide out without floor cuts?
Best type of tank to replace with? Things to watch out for while doing this?
My mechanics will handle as much work as my depleted wallet will allow.
Thanks for any input. Cleveland Ohio is my location.
Jarrett
Jarrett
