on my 84 Bayliner Contestsa I flushed both the outlive (volvo)and exhaust hooked up the muffs started the engines but no water came out of the exhaust. Any ideas.
no water coming out of the exhaust-gctid378399
Tony, Cape Cod, MA
Vice Commodore Bourne Yacht Club
1994 Carver 390 Cockpit Motor Yacht
454 Merc Cruisers inboards
"HOLODECK"
2014 10' hard bottomed Dink powered by 3.3HP Mariner 2 stroke
www.bourneyachtclub.com
Ditto Tony on plugging the drain hole...., and check/replace the water neck fitting.
These are a wear item and require routine replacement.
Any breach in the suction side will prevent the sea water pump from pulling water up/in.
In your completed projects thread, I mentioned; See the BOC Vault thread titled Volvo Penta AQ series frequent Q's & A's for any V/P drive related help.
tonyiiiafl wrote:
I use a piece of duct tape.
Nobody gets out alive.
You may laugh at this... but my plug for these is made from Tremco Vulkem 116 Polyurethane Sealant.
I filled the neck portion of a plastic funnel with Vulkem, let is cure, pulled it out..... and "voilà" ... ya got a near perfect plug that doesn't care if the drive is wet or dry.
I put a lanyard on it so I won't loose it.
mac0ne01 wrote:
Thanks Guys the plug worked. Am good to go thank,s now onto the plumbing
How long did your engine run while you were figuring out that no water was coming from the exhaust?
An impeller can be ruined in as little as 20 seconds if run dry.
I'd remove it, and take a look at it.
Re-install with glycerin on it.
I have been using those little expanding plugs (7/16 inch), stick it in and flip the little lever making it tight. This is just a bypass, incase the intakes get plugged by debri, you have a safety valve to continue sucking water.
