My neighbor installed a Gen-sep on his 1969 44 foot Egg Harbor. I inspected his install and he fired the old Genny up, wow it is very quiet. I have decided to take on this project myself. I am going to re-use my Vernalift muffler and just add the Gen-sep. The moorings in LA at the Island are pretty close quarters so firing my obnoxious Westerbeke at 7AM to brew coffee is just rude. (I do not have an inverter).
I have to mount the Gen-sep to the transom wall up-high near the exhaust loop. This unit will have some pressure running through it and I am a bit nervous about using tiny screws to mount it. I certainly do not want to bolt through the transom and have ugly screws visible next to the "Reel Joy" decal on the back.
My idea is to use a couple pieces of wood maybe 1 x 4 or 2 x 4 and glue them to the transom, then mount the Gen-sep on the wood..
A couple of questions:
Do you agree with gluing the wood to the transom for the mount? If so is a 2 x 4 to heavy? Also, should I use epoxy or 5200 or what for the wood to fiberglass stick?
I am not a mechanic and have dealt with engine hoses, to me they are a pain in the A**. I will have to run new hoses and cut a new hole at the water line for a second exhaust through hull. Is there a trick to getting the hoses on to the through hull, muffler, etc? My thoughts were to oil the end male pieces and to heat up the hose so I can get them on? Any advise on this is much appreciated.
I will photo the entire install and document it here in-case someone else wants to do this upgrade. I am hoping to get this done before Memorial day weekend..
As always, all opinions and advice is welcome and appreciated.
