Electric Head Question...-gctid377563
    dmcb wrote:
    Well one way is a dry flush and the other a wet one.
    There is a check valve in the system so when you winterize keep that in mind. The check valve prevents water from going back in the line it came from.
    Nothing else to do I am aware of.
    Doug
    Didn't know about the check valve... thanks.
  • dmcb
    Doug
    Guest started a topic Electric Head Question...-gctid377563
    I'm now the owner of an electric head whose flushing mechanism is the dial you turn either left or right.
    I'm a newb to all things electric with the head am could use any advice from use to maintenance and what to be wary of.
    Thanks.
