Installing a thruster on my 285, need to decide on wiring options. Where should I put the battery - bow or back?
If bow, how do you charge it? 12v to 12v charger? Do you have any impact from the weight? Or am I right in recalling the 285 is rather light on the bow anyway?
If back, where do the wires go? Port side duct behind galley used by aircon, or starboard side with duct used by waste pipe, or... ? In this case, I'm aware of the cable thickness required to stay above 10v at thruster.
Many thanks,
Eugene
Many thanks,
Eugene
