Help me I.D. this lead on the outdrive-gctid377028
  • Help me I.D. this lead on the outdrive-gctid377028
    Anyone know what this grounds/feeds/etc? Looks like it was attached to that screw, but not sure what it does. Not sure if it's keeping my speedo from working or not. It's a Bravo drive and the boat is a 1998.
    [img]/media/kunena/attachments/vb/680474=27137-boat wire.JPG[/img]
    Its a ground wire for your anoides. These all need to be attached for corrosion. Has nothing to do with speedo. There is a small hole in the back of your outdrive that allows water in. If you trim up your out drive there is a small hose the is attached that goes to your speedo. The hole in the back of out drive is probably plugged.
      It is a common grounding wire.
      Here is the kit with all the wires to give you a general idea of what all is connected.
      Tally and Vicki
      "Wickus" Meridian 341
      MMSI 338014939
        Thanks guys! I'll get that reattached before launching this weekend. I checked the speedo hole and it had a good amount of crud in it. Used a paperclip and a little air pressure to clean it out. Hopefully that solves the problem.
          that drive needs a good cleaning!
            Bonding wire/cable to offer a path for any galvanic current!
            Volvo Penta Duo Prop Drives
