I took the original swim platform off the transom and am getting ready to set up a used teak deck. the problem is that this teak deck is straight across while the Capri has a slightly angled transom. I have a couple of options the way I see it: mount the deck at the angle and cut the deck to allow a closer but still not flush fit to the transom or mount it right above where the 270 leg goes to the full upright position and there is a flat spot that extends along the midpoint of the transom there. Either way I will still have an angle between the ends of the deck and the transom, one bigger than the other. I can try to post some pictures this evening.
Has anyone converted one of these decks for the Capri and what worked for you? Pics would be helpful too.
I have two SS struts and would need to buy 2 more plus the L brackets to install the deck, or buy 4 of the L brackets that have the diagonal supports
which would be better?
thanks
Joe
thanks
Joe
