PLEASE HELP SUPPORT OUR SITE
I had a bulb burn out on my port side running light at bow on my 2005 classic 242, I planned on getting one from our local NAPA but somehow managed to loose the bulb. Does anyone have the part number for this bulb as my boat is stored 5 hours away so it's not easy to go and pull the other side to get the number?
Pretty sure you are looking for this. I am waiting to hear back from Dr. LED to see if they have a comparable part.Perko bulbHere is a pic of mine that I am replacing.
My understanding is that LED replacements behind colored lenses need to be of the same color for optimum performance.
Be careful in this because your nav lights are rated based on a specific lamp. If you had a collision and it was found you modified the nav light this would be bad regardless of whether the light was the same with lamp or LED.
Jim McNeely New Hope a 2004 Bayliner 305 Sunbridge Express Cruiser
Twin 5.7s with Bravo2 drives
Brighton, Michigan USA
MMSI # 367393410
Here is the LED alternate. Interesting thought on the modification. Anyone else have any thoughts on it? I hadn't heard that issue before. Does it need to be the same color? I would like to replace the bulb and not have to worry about it ever again (making it worth the extra cost).
I've found it easiest to just replace the entire assembly vice just the bulb for navigation lights. I've found too often that the contacts are worn/corroded...
The running lights on the 242/2452s are DE 3175. 10 watt festoon bulbs.
Available at walmart in the auto dept for about 3 bucks/pair.
The failure mode is the crimped wire thru the end caps become corroded and loose contact.
failure mode 2: The fixture uses crimp rivits for attaching the wires to the metal strips which carry power. Ditto on the corrosion. Clean it down and solder.
Been there and done that
Captharv 2001 2452
