Just started my new to me 2355 and when it is running the alarm beeps about every 20 seconds,all the guages look ok Any Ideas on what is causing this? 5.0 1998 Also the trim tabs don't work. Where it the fuse box?
alarm-gctid376339
My alarm goes off if the engine starts to run to hot or if the resovor for the lower unit oil gets low.
First find the source of the beep. After finding the source of the beep you should be able to determine what the alarm is sounding for, it will be mounted on or wired to whatever it is that needs attention.
Alarm sounds from high temp, low drive fluid, AND low oil pressure. The drive fluid resevior has been known to have faulty sensors. If your gauges look good I would start with that. Sounds like a faulty sensor to me.
The fuses should be under the dash.
Had same problem, wgen I had it check it turned out to be a loose wire to sensor which i knock off. Walt
