Has anyone tried using a hose clamp to keep a boat leveler hose from leaking where the hose connects to the cylinder? How long will this work as a fix rather than replacing the hose? As far as replacing the boat leveler hose, does anyone know what type of sealant to use where the hose exits the hull?
Boat Levelers-gctid376203
I'd contact Boat Leveler (which is now Insta-Tab I believe), and ask for replacement hose and hose clamps.
The hose cannot expand beyond what the working pressure will cause, and the little clamps must have the correct ID for this hose OD and type.
Rick E. Gresham, Oregon
The company is now called Insta Trim. http://www.insta-trim.com/
Confused on the hose clamp question. How is currently attached? Stock attachment is with an SS hose clamp. Mine had 2.
Ted, if/when the curved area under the worm drive screw does not match the OD of the hose, it may not fully (and in a radial fashion) compress the hose, and they may eventually leak.
This is often the problem with smaller diameter fuel lines, etc, if the clamp ID is not correct for the hose OD.
2850Bounty wrote:
Ah... Insta-Trim..... I was close, but no cupy doll!
Be careful on clamp pressure, as the fitting is plastic.
