4 Blade or 3 Blade on volvo 270-gctid376062
    My boat is a 1985 bayliner 16 foot with an inboard aq125b (125 horse) and a volvo 270 outdrive. I have a 3 blade 14 x 21 r prop on it and I can't get to its full RPM's. At WOT I get to 4200 RPM and its max RPM is 5000. I am looking at getting a 14x19 prop but am stuck on if I should get a 4 blade or 3 blade. Any help is welcome as well as comments and other suggestions!
    Thanks, David
    I should also include that I would like to pull skiers and tubers. Top speed isn't my number one priority, planing out is more important. I heard the the 4 blades can wash out while doing sharp turns.
      have the rpm's dropped off with the existing prop?
      i.e. did it "used to" reach higher rpm with the 21P
        No it didn't. I just got the boat last summer and I started contemplating getting a different prop when it takes for ever to plane out and after reading what RPM's it should be running at at WOT.
          i'd say four blade 19 or 17 pitch, get rpms up and get the four blade hole shot for towing and running heavy.
            If I am having issues with the 21 pitch wouldn't a 19 pitch 4 blade be pretty close to the same in terms of how hard the engine would have to work?
              That extra blade acts like 2" of pitch, RPM-wise. My 16' '83 AQ125A ran a 14x19 at 4800 RPMs. If you go 4 blade, you'd probably be looking at a 17" pitch, like Reel Power wrote. JMO
                First tbear I like your profile picture
                Second the only 17 pitch prop that I can find is a 14.5 inch prop....Does this effect it very much seeing that it's only a half inch?
