PLEASE HELP SUPPORT OUR SITE
Thanks!!!!
Where is the fuse/breaker? Discovery 246-gctid376035
My windlass on my 2007 bayliner discovery 246 isnt working, I get a click from the relay but not motor noise. I found the fuse for the relay but for the life of me cant find the motor fuse or breaker... anyone have any ideas?
Ok I have a lever switch to the left of the panel with the "pop out fuses", it says master accessory switch on it or something like that. I tried to trace the wires back from the windlass, but it goes inside the side of the boat and the only place I see wires that might be them are at the battery connection and there a few of them that look the same. I'm pretty sure the windlass was put on by the factory, so I'm surprised I don't have a breaker labeled windlass or lewmar or something. I'm kinda at a loss as to how to troubleshoot this... I think my next step will have to be to charge up a spare battery and connect it directly to the windlass motor leads via jumper cables. Then if the motor turns I know it's my hidden breaker, otherwise there is no breaker and the motor is bad. Does my rambling make sense?
Btw, tried a new wax today, Griots Best in Show... simply amazing!
Nick
Is that lever tripped? Try resetting it a few times, like when you test a breaker, then make sure its set (not tripped) and try again.
Also, you probably did, but check the connections under the widlass, in the anchor locker. If they dont have a lock washer or lock nut (or even if they do) they may have come loose. Thats why your getting juice at he relay, but not the windlass (maybe)...
Joey
2007 Discovery 246
5.0L MPI BRAVO III
The "BAY-BEA"
