My engine is an AQ260 with an YLM624AV distributor installed. I am rewiring the engine and I have found the ballast resistor is completely open. Rather than buy a ballast resistor, I purchased a new coil with an internal ballast resistor.
Previously the starter "R" connection was connected between the coil and the ballast resistor. With the new ignition (no points), what is the effect of connecting the "R" (purple wire) directly to the "+" of the coil? Intuitively, I say I will be providing fill voltage to the "R" terminal, as opposed to dropping some voltage across the ballast.
