Hi all!!!
So as my return to the summer "maintenance" continues, I have come upon an iffy situation. I changed all the plugs out on both engines(Merc 5.0 2bbl mercarb) and noticed that the plugs a little black for my taste. Not the correct cyan type of color you should want to see. Obviously a little running a bit rich.
now, let me give some background. Beginning of last season both engines were running a bit rough, not idling so well and it was just time to rebuild carbs. Folks, rebuilding carbs is an art LOL After rebuilding both of them myself and only getting minor improvements i had one rebuilt and picked up a remanned one. Well, both engines responded ecellent and run smooth and idle purrrrrfect
Now that I changed plugs I am realizing it is a bit on the rich side.
I hate to monkey around with the carbs, because if it runs smooth, I certainly do not want to nacker that up. Any recomendations if I should play with the mixtures??? And how does one accomplish this task. Is it the forward facing adjustment screw on the carb(the spring loaded one)??
Thanks everyone
Thanks everyone
