On the 1988 Bass Trophy Bayliner or a similar hull or transom, has anyone of you been successful in adding a small (Decided Not 5HP but now Minimum 9.9HP - 35hp) kicker motor on the starboard side next to the 125 Force allowing the kicker to be controlled by the same steering while the 125 motor is up?
Is it possible to have such a small 9.9 HP motor controlled for speed, forward and backwards from 2nd set of controls at the drivers controls?
Basically I am trying to find a kit that would set me up to have a small kicker motor guide me through shallow waters around obstacles in tight spots but controlled from my console and not from the tiller position. Appreciate a lesson here, thanks.
DidleySquat
DidleySquat
