Hi all!
So, now that I have a brand new B3 drive to hang, I figure it's time for new driveshaft and exhaust bellows. And, since the bellhousing will be mostly off to do those, now is the time to replace the trim position sender.
Last Spring I installed a Lvl 2 MercMonitor (engine is 350MAG MPI, SmarctCraft capable), but the drive trim values never got transmitted to the MM, so the ECO function didn't have enough info to work. I tried switching from the "analog trim" lead to the "digital trim" lead, but still nothing. So, I upgraded to the Digital Trim Position Sender that was installed yesterday. Trouble is, it's got 3 wires (red, white, blue), and the installation instructions say there should be a 3-pin plug in the harness that it gets plugged into...I can't find that specific plug. Anybody out there with any advice or TPS experience? Should I have stayed with the original-style sender?
Thanks!
Thanks!
