Was out for 1st cruise on our 1st boat on Sunday. Boat is 1999 Bayliner Rendezvous with 5.7L Carbed Mercruiser V8 and Bravo 3 outdrive. I changed all of the fluids, filters, seals in the outdrive, water impeller, plugs, wires, cap, and rotor on the engine. Left port and was cruising for about 30-45 minutes at 3400RPM, oil pressure at 50psi, and speed was varying between 29 and 32 MPH depending on water smoothness and wind direction. RPM and oil pressure remaining consistent with no variance. I felt a "pop" go though the hull while the engine seemed to hesitate briefly. I was watching the gauges and all was unchanged when the oil pressure dropped to 0psi and the alarm went off. The engine was still running normally, so I throttled back to neutral and shut down the engine. Once the boat slowed to a rest, I opened the dog house to take a look at the engine. No leaks, bilge was dry, no smoke or anything looking amiss. Tried to restart the engine, the starter turned normally but engine would not catch. Check the carb, and was getting fuel when the throttle was operated. Pulled main coil wire into distributor and checked distributor end of wire with no spark.
Got tow back to port. Have not had the chance to check yet, but my gut feeling is that I lost the roll pin that locks the cam gear onto the distributor shaft.
When I get the chance, will go pop distributor cap and check to see if I can turn the rotor by hand. If I can, then that is the culprit.
Anyone else have a similar experience? If this is what the cause is, then I will add some spare roll pins to my onboard toolkit/spare parts bag.
