King cobra shiftrod problem-gctid374444
    So i have bayliner 2455 With gmc 6.5 diesel engine... Now everything is looking good but nobody knows good repair help my king cobra 7.4 sterndrive ,,,what is the correct height for the shiftrod ,,this is what i know,,18,3 cm when neutral but if i but that the shift rod is in the Detent only few rounds i think that is not ok???but when i pull up the shiftrod And but that 18,3 cm looks good but is that correct can somebody help me???
    18.3 cm = 7.203 in
    That is the correct length to set it to.
    " WET EVER "
    mmsi 338108404
    mmsi 338124956
      dktool wrote:
      18.3 cm = 7.203 in
      Thank you a lot ..but do i have to but that neutral manual says that
      Thank you Again
