Hi all, new to the forum, (joined today). I purchased a 1989 2655W a few months ago. It was cheap and needed a lot of TLC, new upholstery, bimini covers etc. Hull is sound and it has a 4 year old Mercruiser MPI with Bravo11 done 180hours. (Originally had a 5.7 OMC Cobra) I bought the boat for less than what the engine cost. Anyway, my question is this:
The water in the shower doesn't appear to drain away. Where does this water go? Someone said there would be a pump to remove the water. The only pump I can find is one under the dinnette seat. I know the pressure pump for the running water is in the engine bay and this works fine. The pump under the seat looks like the pump in the engine bay. If this is the pump, how does it operate? Automatic or manual? Any help would be greatly appreciated.
