Hey guys... I would like to know if someone could guide me to the right direction on a removal (if this is a good idea) of the heat exchanger on my boat. I have this weerd set up and I would like to make it right. as you can see in the pictures it is a bad set up (but it works). I've seen engines with out the heat exchanger with the right thermostat housing (picture attached) any advice on gains and loses by removing this contraption..? I notice that my water temp is under 120 Deg. under normal driving.Thanks for any advice......:worth
[img]/media/kunena/attachments/vb/676950=26749-IMG_2546.jpg[/img]
[img]/media/kunena/attachments/vb/676950=26750-IMG_2549.jpg[/img]
[img]/media/kunena/attachments/vb/676950=26751-Thermostat water housing AQ 225.jpg[/img]
