Has anyone replaced one of these?
Alpha 1 Gen II Gimble Ring Assembly-gctid373530
1998 3055 Ciera
(yes, a 1998)
Previous boat: 1993 3055
Sea Doo XP
Sea Doo GTI SE
Vice Commodore: Bellevue Yacht ClubTags: None
I've replaced entire transom mounts. Use a fork lift to pull the motor, then unbolt the transom mount and replace.
The pivot housing can be replaced when doing bellows installs: http://www.mercstuff.com/bellowsreplacement2.htm
There are numerous videos on U Tube that show other work being done on the Alpha 1 GenII.
*!$! I will be having the mechanics do this.
1998 3055 Ciera
(yes, a 1998)
Sea Doo XP
Sea Doo GTI SE
