I had a previous question here about the gas tank in my 1995 24 ft Trophy. It is apparently leaking and is sealed underneath the cockpit floor. I was told I would probably have to remove the engine to get at the tank or cut thru the fiberglass cockpit floor to get it out. Someone today mentioned that there are rubber like bladders used in aircraft that fit thru small openings in tanks or other enclosures, then are filled with high pressure air to fit into all corners of an existing tank and then can be used as a regular tank. This would preclude pulling the engine or cutting thru the floor. Anyone know of anything like this and does it work.
DBH
DBH
