1985 2750 ciera sunbridge fuel sending unit-gctid372518
    Does anyone know where I might locate a new fuel sending unit for a 1985 2750 ciera sunbridge? It has a 125 gallon fuel cell.
    Try this: http://www.smartcart.com/WemaUSA/cgi/display.cgi
      Pull your existing sender out, and take it with you.
      While many of these use a standard screw pattern, there are several, so it wouldn't hurt to play it safe.
      This will also help you get the correct length and swing for the float arm.
      Make your intial adjustment so that some fuel remains while the reading shows close to empty.
