The tachometer on a Diesel is different from a gas tachometer. I had to take RPM readings from the alternator and purchase a circuit board that converted the signals into gas tachometer signals
I've just copied the above statement from another thread I came across on here
I've recently finished a petrol to diesel repower on a 24ft 1988 bayliner trophy hardtop which originally had an OMC 5.0l/Cobra outdrive, a GM V8 6.2l N/A diesel with a VP 290 DP now sits in its place
Had a couple of small issues during the project, now got another one, when the tacho is wired from the alternator it reads 3000 rpm at idle and on the rear of the tacho there isnt any way of adjusting it, where can I get one of these circuit boards from and will it solve my problem?
Regards
Nick
Regards
Nick
