I'm trying to help a man determine what this oil presure hose is for.
This comes from the engine's oil galley port on a Chrysler Marine 360, and has been "T" 'd in with his oil pressure gauge sending unit.
Nothing has been connected to it that the owner is aware of.... and he is not using it.
Disregard the metal bracket, the oil sender unit, the spring wrapped hose and the T fitting.
The part in question that should identify what this hose is used for, will be the fitting at the extreme far right side of the photo.
It has a small flange or ring on it, it is not threaded, and it has a check vavle in it.
I have a strong hunch as to what I believe it was for.... but what say yee?
Sorry, but this is the only image that I have of it.
Attached files [img]/media/kunena/attachments/vb/675799=26610-AKJohn quick disconnect oil hose fitting 1.jpg[/img]
