Humminbird sounder problem-gctid372236
    I installed my Humminbird 788 and have a problem with the transom mounted transducer. At no wake speed it shows a very clear screen and depth, when I increase speed the readings become messed up and erratic. Any help or info would be great.
    1992 4588
    WitchWay
    Seadoo Wake 170
    A photo of where the transducer is mounted would help.
      I won't be able to take a pic, she is in the water for the next 6 months.
      Its mounted at the lifting strake between the drive and trim tab. Previous owner had one mounted in the same location.
      1992 4588
      WitchWay
      Seadoo Wake 170
        If its mounted at the lifting strake that could very well be the problem. Too much turbulence there. If you don't want to put up with the erratic readings, don't want to pull boat and want a permanent fix buy an angled puck shoot thru the hull transducer from Humminbird. I had one of those on my boat for 12 years. I never lost bottom or had erratic readings. You will have to buy a separate temp sensor that you can install when haul your boat for the season.
        http://"http://store.humminbird.com/...13996/XAP_9_20
          There should be some adjustments you can do in the water. Play with that and see if you can make it better. As said its the turbulence. Raise it a bit, lower it, change the angle. or do as suggested, shoot through the hull.
          You can remove yours from the bracket and use it to shoot through the hull. It will work perfect. Just leave the bracket installed until you get the boat out of the water.
          On another thread yesterday I made a suggestion on how to do that. Its in this thread. http://www.baylinerownersclub.org/fo...installing-gps
          Doug
            I'll try shoot thru the hull.
            Thanks for the advice.
            1992 4588
            WitchWay
            Seadoo Wake 170
