Hi, Can anyone tell me if its normal for one stern-leg to have more sideways movement than the other ? At this point in time our boat is on the hard while undergoing maintenance. The other day while checking the drives i found that the port leg had quite a bit of lateral movement compared to the starboard which was quite firm with little movement at all. Is this normal ? if not what might the trouble be and what should I do to correct ? The port side also has a bit of a growl once its put into gear with the motor running. Any help or advice would be appreciated.
Cheers Steve
Cheers Steve
