As far as I could search, Blue Sea Systems does not make a Remote Battery Switch (solenoid) that is single pole, double throw (i.e. connect a common terminal to either of two possible terminals). So, I implemented one using 2 Blue Sea Systems RBS switches. These switches are "ordinary" solenoid operated magnetic switches; Momentary push on a remote button causes the solenoid contacts to close and momentary push to open them causes the solenoid to release. I wanted to connect either battery #1 or battery #2 to port no. 1 of my MBSS, remotely. That way if I set the MBSS to No. 2 position, my no. 2 battery is enabled. If I set the MBSS to No.1 position I can remotely select which battery gets enabled. Each of the Blue Sea system RBS switches comes with its own Contura 2145 switch to enable or disable the desired battery. The RBS control schematic shows I should apply +12v to ORG or +12v to BRN wire to open or close the solenoid switch, respectively. Since I wanted either battery No.1 or battery No. 2, but NOT BOTH or NOT NEITHER (i.e. always have one or the other battery to be enabled), I thought I could get what I wanted by wiring the ORG wire of RBS#1 together with the BRN wire of RBS#2 and also wire the BRN wire of RBS#1 together with the GRN wire of RBS#2 so that if one RBS was given the command to open the other would be given the command to close, and vice versa. This configuration did not work (when I operated the Contura switch, a momentary "hum" was heard but solenoids did not change state) and I was forced to use two separate Contura switches to control the RBS#1 and RBS#2 separately. This works but, if possible, I want to avoid having an operation mode which, even momentarily, may make both RBS's OFF (if I disable one battery before enabling the other), which may mean some of my electronics lose power.
Does any one know why a single switch does not control two RBS solenoids in opposite directions?
Thanks,
Thanks,
