The motors for my outdrive trim seem to be working fine, they lift and lower the drives like they are supposed to, but once the port side reaches the full down position, it makes a very loud, horrible, screeching noise. My stbd outdrive is the exact opposite. You can barely tell a difference in tone when it reaches full down position. In every other boat I've ever been on, there is a very distinguishable change in tone when the drive reaches full up or down position, but nothing loud or alarming. That is not the case with my port side.
So my question is, is there something that I should be greasing or putting oil on with regards to that trim motor?
Thanks. John
Thanks. John
