Does anyone know how to access the bilge or the shower drain in the main cabin of a 1985 Bayliner 2550 Ciera Designer's Edition?
Bilge Access-gctid370279
I have an 87 2560 flybridge and on mine you can access under the shower pan by removing the step in front of the door and then the panel beside the step. Simply remove the screws. Be careful with the panel, I had a hard time removing it and puting it back, due to it beeing there for so long and the carpet. Good luck. Let me know if it works for you.
