Hi Folks
I am trying to locate a a circulating pump for my cruisair a/c system. It is a TaylorMade model # PML 500L. It is a 115 Vac-2.0amp-60 Hz. The serial # if this helps is a M99 0177 and the GPM is 490 for 3 feet.
I have found a PML 500 which is under the Dometic brand name at Greatlake Skipper for $349.00. I believe the amp rating is 2.5 but everything else looked the same. I even found the dometic PDF and there is no PML 500L anymore just PML 500
This is for a 2001 Maxum 3000SCR. Is there a dealer that might have this?
Any help will be much appreciated
Roger
Roger
