Standard Horizon electrical connectors - where to buy?-gctid368987
    With the boat came with an Airmar B744V transducer (dual frequency) - and the more I read the more pleased I am that I have this - apparently it's a pretty good piece of kit. And I bought a Standard Horizon CPF300i FF/plotter to mount on the upper helm. One of the reasons I chose this plotter is because according to the factory rep it's compatible with the transducer. Everything I read backs this up - including a x-over wiring diagram from Airmar (attached).But I need to purchase the (waterproof) 8-pin connector that will allow me to terminate the cable. Does anyone know if this is a proprietary connector or if it's available "off the shelf"?
    [img]/media/kunena/attachments/vb/672377=26202-wiring diagram - AirmarB744V - SH.jpg[/img]
    ________________
    1998 Bayliner 4788
    1989 Bayliner 3270 - SOLD-
    Try GEMECO marine assys. They are the Airmar distributor. They have many adapter cables, but they are wholesale only, they have made axceptions, if noyhing else they can give you a part no.
    It is a Standard/Sitex 8 pin what is your existing transducer conector?
    PH. 1-843-210-7000
